跳转到主内容
加入维修社区 - 创建账户
How do I reconnect a broken iSight cable?
As the photo shows, I wonder how do I connect them back in correct sequence, black-white-green-red?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
That doesn't look like any iSight that I'm familiar with. What device is this a photo of?
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Kyle, that's the the iSight/Mic board, looking at the inside top of the the iMac bezel. The cut cable is most likely the mini USB feed.
Unfortunately, I haven't yet located a good pic showing these wires - as there is shield foil over the connection normally.
I did find the whole part available on eBay here: http://cgi.ebay.co.uk/iMac-G5-17%22-iSig...
Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
with the cables on the left and the camera lense pointing away from you there will be 4 contact points on the left side of the board this where the cables connect starting at the top, on the top edge where the isight lens is the order is as follows
black
white
green
red
hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
talentsky724 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 2,745
