跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
247 个问题 查看全部
Will my capacitor support
Hi
I have a 3 farad capacitor for car audio. I recently upgraded my amps and subs and I'm now stuck with the dimming lights problem.
My question is Will a 3 farad cap support an 8000watt monoblock enough to stop the dimming? And are there any risks to doing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The old-school rule of thumb for stiffening capacitors was 1 farad up to 1000 watts. So 3 farads should be good for about 3000 watts. But there are lots of other factors, such as the impedance that the amplifiers are driving and the type of capacitor (normal, hybrid, carbon, etc.). Low impedance loads, such as 1-ohm subs, will draw a lot more current from the amplifiers than a higher impedance load. If you’re really running 8000 watts, then you’ll likely need a second battery and an isolator in addition to stiffening capacitors. And 3 farad might not be enough, especially if your subs are wired to a low-impedance load. 8000 watts is an awful lot of power to be running through a car’s electrical system, so plenty of power supply upgrades are going to be needed to avoid straining the rest of the car’s electronics (and the lights).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tyrone Myburgh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 84
