跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
front screen cracked cant slide to unlock
front screen cracked and i cant unlock the phone to do anything at all is there some way i can unlock it other than using the slide that appears on the screen? .there is a new screen coming but it won't be here for a week or so .
thanks mike.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hey Mike did it work after you changed your screen or did you have to do anything else to fix it?
完成的
添加一条评论
6个答案
已选择的解决方案
if you cant slide to unlock then the digitiser is broken and all touch functions won't work. sorry but you'll just have to wait for the new screen.
这个答案有帮助吗?
得分 3
2条评论:
ok i was hoping that wouldnt be the answer but thanks . i'll just have to wait .cheers Mike
完成的
i have the same problem do you have to do anything else to have it fixed or just change the screen?
cheers
完成的
添加一条评论
I cant get my iphone to unlock like at all i mean i can hit the home button but it wont let me play music or unlock or slide to unlock my phone what the !@#$ is goin on with my phone
这个答案有帮助吗?
得分 2
添加一条评论
yeah but that's not true. the same thing has happened with mine, but i can double click the centre button to play music (touching the screen to press play and pause etc.). so the touch screen works, its just that specific part of the screen that doesn't work. there must be some way!
这个答案有帮助吗?
得分 0
2条评论:
If there is a specific part of the touch screen that does not work, it is still your touch screen that needs to be replaced. Your touch screen is build with an "internal grid" and if it is broken at a certain area, that area will not function, while others do.
完成的
oldturkey is right here...any area not working can't be fixed apart from replacing the entire digitiser.
完成的
添加一条评论
I have the same problem with my Huawie touch screen mobile, all I did is I asked a friend to call me and once I receive the phone i reply and hang off immediatly to unlock the screen.
Although its not at all a practical way to ask someone to call u everytime u need to use the phone but atleast it works.. So good luck till the screen is repaired..
这个答案有帮助吗?
得分 0
添加一条评论
mine is badly crashed actually it was smashed in the car's door.
It doesn't unlock and the central button does not work, actually I-tunes does not connect it asks me to unlock it , I need to get some data from it... what can I do?
这个答案有帮助吗?
得分 0
添加一条评论
My phone was cracked reallyyyy bad (a friends fault, not mine). When it cracked, everything worked perfectly. After a year (This is today) I took my phone in the bathroom with me and put it on the toilet while I took a shower, all the while my phone having a life proof case on. Then, when I went to pick up my phone, I dropped it. It did not crack anymore, but the touchscreen will not work at all. I mean, I can only use the home button, the power button, and the speakers button. I can see when people text me too. This is a big problem...... can someone help?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Jeffery 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 17
总计 78,287
