跳转到主内容
Repair information and troubleshooting for the Dell Inspiron 15R N5010 laptop computer.
48 个问题 查看全部
My laptop produces a whisle sound
my laptop does not start and produces a whistle
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
hoby25588 , you could try a resest, disconnect the charger,remove battery,press down the power button for 30 seconds, install battery and charger, power on system. The whistle you here may be a faulty fan,take laptop apart and give a good cleaning especially the fan and try, a can of compressed air should help blow dust, etc. out. If fan is still not functioning properly replace it, as it can cause issues. If it is not a whistle and computer is beeping, these are error codes depending on the amount of beeps. Use the link below for explanation of beep codes and possible fixes. Good luck.
http://blog.parts-people.com/2014/06/27/...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
hoby25588 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 45
