跳转到主内容
MacBook Pro 13寸显示器版本
9729 个问题 查看全部
Static noise after 4-5 hour of use.
Hi!
I have a 13 inch Pro, and after 4-5 hours of use, i get an annoying static noise from the machine.
I check the ventilator, but there is no dust in it, so i think the speakers make this noise.
Any ideas? Thanks
(And sorry for my bad english, i hope you understand everything.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Does changing the speaker output or volume stop or change the noise? If it doesn't=HD,or fan. If it does=Audio problem.
完成的
添加一条评论
1个答案
已选择的解决方案
Could also be
a rattling HD, indicating eminent failure. Be sure to backup up frequently Until you know if this is HD or Speakers.
If changing the Audio Output or Volume does not change or stop the noise, boot from a startup DVD/CD or external drive, then use Tools or Utilities->Disk Utility->Disk First Aid:Verify Disk to check for problems.
Run the machine for 4 or 5 hrs. If the behavior continues you'll have to open the machine to determine if it's a fan a bearing noise, or if it's coming from the HD. You may have to employ a probe (a dowel or screw driver) one end lightly resting on device other end to your ear, to isolate the noise.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 0
1条评论:
Thanks!
I run the Verify Disk option, and everything is fine(at least he say that:))
Tomorrow i try to open up and check the source of the noise.
Thanks
完成的
添加一条评论
添加你的答案
gtpassatgt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,443
