Touch ID fails, double tap works
Hi everyone!
After I replaced the screen (screen only) on my iPhone 6S, the Touch ID fails - even though the double tap for one-handed mode works.
I already transfered the small conductive plate beneath the connector (like described in Touch ID not working after screen replacement?) and took everything apart and reassemled it plus did a factory reset and disconnected the battery.
I was very gently while transferring the home button to the new screen - there is absolutely no optical damage.
What would be the next, you would try?
Could it be a problem, that I used the phone for testing purposes with another display and home button for some time?
Thanks for your help in advance.
3条评论
The chances are the home button extension cable may be faulty on the replacement iPhone 6s screen, every screen comes with it assembled together.
由 Ben 完成的
Well, that's worth a try! I'll check it with the old broken display tonight. Thanks :)
由 Sebastian 完成的
Didn't work with another screen. Either the Touch ID IC is broken or ... :-(
由 Sebastian 完成的
