跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1451 个问题 查看全部
Touch id not working after flex cable replacement
Hello,
I recently replaced my LCD and I might have pulled too hard on the flex cable when removing the metal backing plate as when i put the phone back together everything worked except touch id failed. So i ordered a new home button flex cable and when i replaced it, touch id initialized but did not recognize a finger. The fingerprint comes up but does not turn red to recognize my finger. I tried re adjusting the cable but still does not work.
What could it be?
any ideas...?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
Touch ID is a complex thing, your phone will only talk to the home button that it came with, install a 3rd party one or damage the home button flex and only Apple can get it working again.
Some third party extension flex (the middle bit behind the metal plate on the screen assembly) are not made to the same standard as the Apple ones, and can cause this problem.
Before buying a new flex cable, check that the Touch ID grounding clip is not damaged and in positioned properly, if this is damaged static build up can stop the Touch ID working properly..
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Andrea G 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 152
