跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3886 个问题 查看全部
iPhone 5S no display but backlight
Hello,
Happy to send my first message on this forum! :)
So my request is about an iPhone 5S.
He start completely but nothing are display and the backlight still works.
L19 coil has a little water damage, the pin 1 of L19 probably short to the gnd through the metal plate.
But he seems no dead, how can I test it properly?
And are there any other parts to test in this area of the logicboard known for display issues?
Can this coil cause that or it's more like a death of the U3 LCD controller chip ?
Help me understand please..
Thanks in advance!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
So after peeling iPhone 5S diagrams, I just check the power input and I find the standart value : 1,8V / 6V / +5.7V / -5.7V
Does it always point to U3?
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
I am concerned about your comment "has a little water damage". Water damage can be very insidious. Although you may see just a bit, there can be extensive water damage under the shields, under the IC's etc. Sometimes the repair is straightforward, other times it can require extensive troubleshooting. The best thing to do first is a complete decontamination, then troubleshoot.
Are you an experienced tech looking for detailed help or an avid DIY'er looking for guidance? If the latter, then look for an experienced shop specializing in micro-soldering and water damage repair.
Update (11/22/2016)
Generally speaking, coils such as L19 rarely go bad. They are, by design, a short circuit. That said, some corrosion may have eaten through the wire and made it an open-circuit but that should be easy enough to check. You can remove L19 to check it properly. Also check the bare pads to see if they are not shorted to ground.
L19 connects from PP_VCC_MAIN to Chestnut. What voltage do you read there?
If everything looks okay, including the coil, I would try to replace chestnut.
这个答案有帮助吗?
按维修分数 1
评论:
Thanks to answer!
Yes I know the ravages that can cause oxydation..! But in this case, the emi shield showed signs of water in a restrained area of the board, precisely on L19 coil.
And yes I forgot to specify that the phone was properly cleaned in isopropyl alcohol (without emi shield) before anything.
I'm refurbishment tech but I would learn the hardware troubleshooting. I have knowledge in micro soldering and electronic.
So I believe I'm looking for tech who have encountered this kind of problem.
添加一条评论
添加你的答案
Arthur Trouillot 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 13
过去的30天: 42
总计 1,492
