Why my screen got dark blueish with horizontal lines after charging
Is this means that screen has to be replaced or maybe is another reason ?
And also after I replace battery I can"t get it charge.Phone gets very hot,
Regarda
jpgo@op.pl
This is a very common issue when the screen has been user replaced. If the wrong screws have been installed in the wrong place, the screen might have a blueish tint with other issues arising as well. This is because the longer screws would hit a PCB on the other side. Try removing all of the screws you had to take out and try to see if that fixes the problem.
这个答案有帮助吗?
Thank You for an answer,but none of his had a place.Phone wasn’t disassemble and screen wasn’t replace.This means that screws couldn’d be misplaced.Phone was perfectly ok. till last charge.After charging screen was ok. And than for some reason screen went blueish.Vibrator still works.I thought that maybe battery was flat,so I bought new one and try to charge,but it couldn’t only phone got very hot.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
2条评论
Was the screen changed recently?
由 Garrison Babbitt 完成的
由 Jerzy Goral 完成的
