跳转到主内容
加入维修社区 - 创建账户
第一代 Grand Cherokee ZJ 的维修指南和支持,这是克莱斯勒 Jeep 部门生产的一款高档中型 SUV。
How can I fix the horn button on the steering wheel?
My horn stoped working, replaced it, checked all wireing, good!
Still doesnt work, it hás to be the button on the steering wheel, How to fix it?
Jeep grand cherokee 1998 button in the air bag!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My 1998? Grand Cherokee fuse block 13 near the floor in front of the passenger door is 15amp “Hazzard” so this does not sync? My horns will NOT shut OFF unless the relay is removed from the power center above the right front fender. It is not under the glove box as you are saying? This is why I am guessing that the horn switch in the steer-ing wheel is defective (locked in the contact Position causing the permanent Ground. -I have NO Cavity reference numbers on the relay cavity or on the relay shell. therefore I’m unable to Measure OHMs or Volt as in your instructions. I’’m questioning IF my Jeep Door stating Manufacture 7/96, though title as the 3rd owner reads 1998 the door may have been replaced from a salvage yard? Thanks for giving the instructions for replacing the horn switch in the steering wheel.
完成的
添加一条评论
2个答案
已选择的解决方案
hugoh84 before replacing the horn button I suggest that you also check Fuse #13 in the fuse block as well as the relay and the horn itself. This from the service manual:
"HORN RELAY
Inspect 20 amp fuse, #13, located in the Fuse block.
Replace fuse as required.
Depress Horn Switch. The relay contacts should click. If ok, go to HORNS. If not, go to next step.
Remove relay (BLACK) from the relay center located under the glove box (Fig. 5). There should be battery voltage at cavity 1. If not, repair open in circuit to relay.
Depress horn switch. Measure resistance between relay cavity 2 and ground. The meter should read zero ohms. If not, repair open to horn switch ground.
Measure resistance between relay cavity 4 and ground. The meter should read almost zero ohms (horn resistance) If OK, replace relay. If not, repair open in circuit between relay and horn.
HORN
Measure the resistance between the horn connector pin B (black) and chassis ground. The meter should read zero ohms. If not, repair open to ground.
Disconnect horn connector. Depress Horn Switch. There should be battery voltage at the horn connector pin A (dark green). If OK, replace horn assembly. If not, repair open to relay.
If you really want to mess with the switch, here are the instructions for that:"
HORN SWITCH REPLACEMENT
WARNING: BEFORE BEGINNING ANY AIR BAG SYSTEM COMPONENT REMOVAL OR INSTALLATION,
REMOVE AND ISOLATE THE NEGATIVE (-) CABLE FROM THE BATTERY. THIS IS THE ONLY SURE WAY TO DISABLE THE AIR BAG SYSTEM. FAILURE TO DO THIS COULD RESULT IN ACCIDENTAL AIR BAG DEPLOYMENT AND POSSIBLE INJURY.
(1) Disconnect and isolate the battery negative cable.
(2) Remove 4 retaining nuts from back of steering wheel. Remove air bag module.
(3) Disconnect wire from rear of air bag module.
(4) Place air bag module on a clean level surface with pad facing upward.
(5) Pry out 2 trim cover buttons on back of steering wheel to access retaining screws for the horn switch.
(6) Remove 2 screws and disconnect horn wires located in the lower portion of steering wheel. Push wires through the access holes and remove horn switch.
(7) To install, reverse the previous procedures. Use caution not to pinch wires.
这个答案有帮助吗?
得分 3
3条评论:
Could this be the same for a
96 Jeep Cherokee sport?.
I can hear the horn clicking. But I can't find any bad wiring or fuses Or relays
完成的
@ottedakota2011 sure it could be. what are the issues with your Jeep?
完成的
Steps 2 thru 6 may apply to a Cherokee, not a Grand Cherokee (ZJ). The ZJ has only three 8mm bolts to remove the airbag/horn module, (and the red horn ground wire blade connector) (and of course unplug the yellow airbag itself) . The horn button is then inside the black plastic cover of the airbag. Before you tear into it, here’s a poorman’s suggestion:
1. Before disconnecting the battery or the airbag module, lock the doors with the keyfob. If the horn chirps, it is not a fuse. 2. Disconnect the battery. Remove the airbag module ( 3 8mm screws, etc). With the airbag module unplugged and completely removed, reconnect the battery, touch the red wire blade connector to ground (metal on the wheel etc). If the horn sounds, its your tired or failed center switch on wheel (“press-to-honk.”)
3. Get out your voltmeter. Set it to Ohms, connect to the red blade and black feed wire. Press the buttons in various places and both sides at once. You may just have a sensitive,tired switch.
完成的
添加一条评论
Hi @Wilburn Jones,
Just to help (or maybe confuse you even more, apologies if it does) here’s a link to the horn section from the 1997 Jeep Cherokee repair manual. I realize that you said 1998 (or perhaps 1996?) but maybe 1997 being inbetween may provide some answers ;-)
Here’s a link to the wiring diagram section of the repair manual which includes the horns.
Here’s an image taken from the wiring diagrams showing the circuit details.
(click on image to enlarge for better viewing)
To make it easier to read the manuals, download them to your computer. Just click on the download icon, to the right of the Zoom 100% at the bottom of the document window.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hugoh84 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 46
总计 21,129
