跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4919 个问题 查看全部
Possibly long screw damage?
http://imgur.com/a/e5JML
Here are some images of the screw holes, i just want another opinion if it could be long screw damage or not?
Tried a new screen, its all black but i can hear when i connect the charger, so i googled a bit and it seemed like it could be long screw damage.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
By the look of the holes, there appears to be copper visable, which would indicate damage to the traces by the wrong screw being forced in, however its very hard to confirm without looking at it in person.
这个答案有帮助吗?
得分 0
添加一条评论
look near the lcd connectors if any diode is missing . if not try another lcd , if non of those won't work than you have an light ic issue and you have to change it
这个答案有帮助吗?
得分 0
评论:
Thanks ill look into it.
完成的
添加一条评论
添加你的答案
Harald Frisak 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 69
