跳转到主内容
The Nikon 1 AW 1 is a waterproof camera manufactured in 2013. This camera is Wi-Fi capable and records in 1080p with a 14.2 MP lens.
Why doesn't it connect to wifi anymore?
I was using my Nikon 1 AW 1 the other day and I had no problems connecting it my home wifi. However, today I go to use my camera and now it won't connect. Is there anyway I can fix that or do I need to replace the camera completely?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Great question! Firstly, make sure you turn the camera on and off to see if that helps. If not, make sure the settings are set to allow wifi connectivity. If neither option helps, then you can certainly repair that without having to replace the whole camera, though it will take a little work. If you replace the motherboard then the wifi components (drivers/hardware) will be replaced with it. You'll only need to buy another motherboard for the Nikon 1 AW 1. Here is a detailed guide on how to do it yourself!
Nikon 1 AW 1 Motherboard Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua Bohorquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 249
