跳转到主内容
The Samsung NP-N130-JA01US 10.1 inch Netbook PC was released April 23, 2010 and runs the Windows 7 Starter Edition operating system.
4 个问题 查看全部
What is wrong when my battery doesn't receive charge?
I have been trying to charge my computer with its charger but it is not receiving any power to the computer. I have recently bought a battery charger to charge the battery itself but it is not working. Anything that I can to fix this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
you need to check 1 or 2 things, try replacing the battery to see if that is the case, or it could be your charging port. worst case scenario it is the motherboard
这个答案有帮助吗?
得分 1
1条评论:
Thank you! Well try and see if that works.
完成的
添加一条评论
Is the computer turning on when its plugged in to the wall? If not, take the battery out of the laptop, and see if it turns on while plugged in with no battery. If it still doesn't work, then it could be your charger is bad, or it will be a problem with the charging port on the laptop, or a problem with the motherboard. A dead battery shouldn't stop the computer from turning on unless its also causing a short circuit which is not very common.
If you brought this into my shop, the first thing I would do is test a new charger. If you don't have one, see if there's a local computer repair shop nearby where they can plug in one of their chargers for you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jorge Quintana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 242
