跳转到主内容
Suddenly no power to DVD VCR combo
I have a Sony DVD/VCR SLV-D271P. Everything was fine until I was rewinding the VHS tape & all of a sudden it just went dead. There was a faint blinking on the display panel but it was so faint I couldn't tell what it said. I plugged it in later & no power at all. I checked the fuse near the power & it was fine & I don't see anything looking damaged or not right. Any idea what might be the problem? Thanks for your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
is your device plugged into a power strip? is your power cord detachable from the device. Probably need to get a new device.
完成的
Tried plugging directly into a few different outlets with same result. Power cord is fixed
完成的
Did you get it working?
完成的
I have the same problem & my fuse looks fine
完成的
@brokendown you have the same problem and have the same make and model?
完成的
添加一条评论
2个答案
最有帮助的答案
arch start by following the troubleshooting flowsheet
The components mentioned in the flowsheet are on the same power board as the fuse. If you post a couple of good images, use this guide for that, we can help you point those out.
这个答案有帮助吗?
得分 2
添加一条评论
I have no idea what the flow chart is depicting & where to look. I will take some photos of the board around the fuse in the morning . Hopefully you can see the problem or let me know specifically what I need to do. Thanks
Please let me know if you see where the problem may be or what I need to do. Thanks
这个答案有帮助吗?
得分 1
1条评论:
Did you check your Fuse?
完成的
添加一条评论
添加你的答案
arch 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 18
总计 5,022
