iPad Air won't charge
I bought an iPad air broken off of Swappa. The owner said it wouldn't charge. Once I received it I opened it up and soldered in a new charge port. That didn't work. Any idea what else the issue could be? I put in a new battery and it powers up just fine and works flawlessly. When I plug it into a computer, it doesn't recognize it.
most likely Tristar chip is bad. Possible bad solder joint on the port, so double check that
由 Josh W 完成的
