跳转到主内容
加入维修社区 - 创建账户
2011 年 6 月发布的 10.1 英寸安卓平板电脑。 三星 GT-P7510MA
How to recover from bootloop (only download mode, no recovery mode)?
Samsung Galaxy Note Tablet 10.1 (GT-N8013)
Device hangs at Samsung Galaxy Note 10.1 logo.
Apparently stuck in a bootloop - will automatically turn on and hang at logo following power off via power button.
Able to access download mode, but no recovery mode.
Flash with factory firmware (.pit and .md5) files via ODIN with "Pass!", but bootloop remains.
Kies (pre- Note III) fails to connect with device. Program instructs to restart device.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
try loading stock recovery via odin, then boot to recovery and clear data.
完成的
I've tried loading stock recovery, TWRP, CWM, and Philz via Odin3 (v3.12).
I receive "Pass!" result in Odin software for all flashes, but still unable to boot into recovery.
When attempting to boot into recovery, the logo appears for 2-3 seconds. The screen then goes dark. Backlight comes on for 2-3 seconds. Screen goes dark once again. Then logo appears and the tablet hangs.
完成的
Hey, I got the same problem. Also I have problem with me having some bitcoins inside the memory/Hard drive of the tablet. Is there a way to access only the folders inside the tablet, even if it is stuck in boot loop?
完成的
Hello! Has anyone fixed their note 10.1? I'm having that problem now and I did Odin too but was unsuccessful. Please share if you did rdjackson225@yahoo.com. Thanks!
完成的
Yes, i fixed it by re-flashing TWRP recovery .img file using heimdall flash tool.
https://forum.xda-developers.com/t/how-t...
完成的
添加一条评论
2个答案
已选择的解决方案
This is an old tablet. ODIN 3.12 likely won't work. Find an older ODIN like 3.08 or 3.09. Find the OEM firmware from here.
Remember before this, you need the latest ADB drivers from here.
这个答案有帮助吗?
得分 2
添加一条评论
Sadly after reading 14 pages on Samsung’s web site of this same or similar issues on the entire 8000 series tablets.
it appears Samsung purposely sabotaged these tablets to brick themselves at or about the 4 year life span.
Shame on you Samsung.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 10,956
