跳转到主内容
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
411 个问题 查看全部
Power light turns on, but the speakers pop and it turns off.
So I was letting my 5 yr old brother use the device (foolish, I know, but I'm just too nice a guy for my own sake), and he dropped it on the ground. It immediately shut off and now what's happening is I press the power button, the light goes on, stays for a few seconds like usual, but then the speakers "pop" and the whole thing is off again. I tried opening it up but couldn't find anything I could recognize as out of order, but then again I didn't really go that deep. Does anyone know how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
最有帮助的答案
You should check the ribbon cable connection also may have a bad/broken fuse. You will need to test current of the fuses if the ribbon cables are fully seated.
这个答案有帮助吗?
得分 1
2条评论:
How do I check those fuses?
完成的
How do you check the fuse
完成的
添加一条评论
The same thing is happening to me but one of the cables of the speaker is broken
这个答案有帮助吗?
得分 0
1条评论:
yeah i have the same problem but i spilled pop on it
完成的
添加一条评论
So I actually know what is happening here. A specific cable going from the mother board through the hinge without a light, to the top screen and speakers, is broken. This is caused by this cable being cut like scissors by the hinge. I cant really explain it well, but I know a You-Tuber who can explain it in detail and how to repair it. His link is here: https://www.youtube.com/watch?v=eAVDyIWg...
There is also a part 1 where he takes apart the 3ds, but its not a 3ds xl, so i recommend using the guide to replace the upper screen that ifixit has, but don't replace the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ace in the Hole 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 667
