跳转到主内容
Released on June 1, 2011, with model number A665-S5170, which can be found on the bottom of the laptop.
Why isn't my computer retaining charge?
My computer works fine when plugged in, but when I unplug it, the battery loses charge really quickly! Is it a problem with my battery? Or is it some other issue? How can I tell?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
If your computer boots when plugged in, your battery is most likely faulty, and you will need to replace it.
Try checking out our troubleshooting guide for the Toshiba Satellite A665-S5170 if you have any more questions!
这个答案有帮助吗?
得分 1
添加一条评论
It apers to be a failed or dying battery, so the fix is to replace the battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chelsea Teague 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 181
