跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
97 个问题 查看全部
Doesn't turn on with a good battery
Hello all,
I have a 2nd gen nexus 7 that won't power on. I first thought that maybe it was just a dead battery and bad charging port, so I soldered in a new charging port. No dice. I then took the charged battery out of another working nexus 7 and popped it in. Still not starting.
I of course tried holding the power button down for a long time and to try and boot it into the bootloader/recovery screen. Nothing.
The only other thing I've tried so far is switching the silver ribbon cable from the nexus that works, and that didn't work either.
I can see that the motherboard has been taken out at some point because the seal on the screw was chewed up, however the seal on the daughterboard was fine (could've still been removed and replaced carefully). I don't really know where to take it from here.
I can do SMD soldering if that helps.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
will not power up. Fitted new battery, checked both batteries and charger with test meter , all ok. but will not power up in any way , any ideas?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
You said " I of course tried holding the power button down for a long time and to try and boot it into the bootloader/recovery screen. Nothing. "
Is this the procedure you used to get there?
Press and hold Volume Down and then press and hold Power (so that both buttons are being held together) until the tablet turns on. You should see the word “start”
Press Volume Down twice to highlight Recovery Mode.
Press Power to confirm your selection
Hold down the Power button and press and release the Volume Up button once
Press Volume Down twice to highlight Wipe Data / Factory Reset and press Power to confirm
Press Volume Down seven times to highlight Yes - Erase All User Data.
Once again, press Power to confirm
After the reset is finished, reboot your device.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
hollon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,643
