跳转到主内容
修复你的物品
维修的权力
配件 & 工具
了解您在设备上维修可能所需的技能。
50 个问题 查看全部
heat platen on heat press for sublimation
Platen on press does not heat, is this repairable?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
How about giving us a make and model number. I'm not even sure what it is but it kind of sounds like a iron to me.
完成的
Or a laminator or heat sealer perhaps.
完成的
@mayer @jayeff I think it is a large iron/table for transferring print/pic's onto clothing/t-shirts, Not positive, but a neighbor had one for his business.
完成的
Sorry, I am not even sure what it.
完成的
Hi, Try posting some pictures of it here. Perhaps somebody will recognize it.
在已经存在的问题里加入图片.
Also if you have an image of it you could try using Google's image search feature which tries to match the image with known images.
https://www.google.com/intl/gl/insidesea...
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
已选择的解决方案
Notto, The press is probably repairable, contact the manufacturer and see who they recommend to look at it or if they have a listing for which part may have caused your press's no heat issue, maybe just a internal fuse to replace. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nottoocommon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 83
