跳转到主内容
修复你的物品
维修的权力
商店
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5190 个问题 查看全部
Home button not working
Just wondering if anybody has any other troubleshooting methods to get the button working again, fingerprint sensor works fine
- Replaced home button extension cable
- Restored/updated phone
- tried recalibrating
or does anybody know a shop that can transfer the IC etc over to a new home button?
The cable hasn't been ripped and it just stopped working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
It is possible that the small part under the button is damaged ( I forgot what it is called)
But if you can fill the "Click" or you know the part is not Damaged follow these steps
1.Press the Sleep/Wake button to lock your device. 2.Wait a couple of seconds.
3.Press the Home button. Your device should wake up.
If your device doesn't wake up, follow these steps. Test the Home button after each step:
1.Restart your device.
2.Check for debris or dirt around the Home button and clean it with a soft cloth. 3.Remove any protective film or case that covers the Home button.
If the Home button still doesn't wake the device, or if the button is damaged, contact Apple Support.
这个答案有帮助吗?
得分 1
评论:
nope because the button clicks in
完成的
添加一条评论
添加你的答案
David F 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 109
