跳转到主内容
A digital SLR camera by Nikon sold between 2005 and 2006.
I can't seem to get the timer to work
I press the timer button and the shutter button. The red light does not come on. I've pulled the battery and I've taken the lens off and back on that usually works when I have a problem? What am I doing wrong with the timer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Have you ensured that you have turned the timer function on using the mode button?
Here is an image taken from the user guide for your camera. Click on the image to enlarge it for better viewing.
Update (11/06/2016)
Hi,
Try pressing the reset switch, located on the bottom of the camera to see if this restores the timer function.
Be aware that you will have to reset the date and time again after doing this.
这个答案有帮助吗?
得分 3
3条评论:
yes I am trying to use the timer function button but like i said when i press it the red light does not come on when i press the shutter button and the timer does not activate.
完成的
Perfect, thank you, didn't know that button was there and I've had this camera forever.....the size of a pencil tip!
完成的
Thank you for you help!
完成的
添加一条评论
添加你的答案
Angela K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 185
