跳转到主内容
修复你的物品
维修的权力
配件 & 工具
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3030 个问题 查看全部
Having problems replacing battery in iPhone 4S
A friend sent me an iPhone 4S and said it worked. When I received it, however, it would not turn on. I thought the easiest and cheapest solution would be to replace to battery, so I ordered one. Once I opened the phone though, the battery replacement was not the simple choice I thought it would be . To top it off, my cat seemed to like playing with the tiny screws and I could not find them. Where can I get such small screws (and whatever other small parts that might have been lost), and what do I need to do to get the replacement battery in (hopefully that is still the problem)?
Thanks for any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Phone should be able to turn on without the screws installed.
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
iFixit sellsiPhone 4s screw set.
However, as @Ben noticed, the phone should be able to turn on without the screws installed. You should have removed only a few screws and no other part to access the battery.
Hope this helps !
Vincent
iPhone 4S Screw Set图片
产品
iPhone 4S Screw Set
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Beeman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 33
