跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Overheating? wont make calls all-touch stops.
I had a customer bring in an iPhone 6 that gets very hot. I am wondering if its a lost cause, it turns on and stays on gets very hot the digitizer stops working, it wont make phone calls. its connected to wifi says service is there. i Tried a new battery and screen and the same thing still happens. i have checked their settings and nothing is set to stop calls. if anyone has any experience with this particular issue i would LOVE to know how you fixed it, or if its not fixable at all. THANK YOU
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Almost certainly board level damage. Usually due to water damage but it could have been due to a drop. Since multiple systems are not working, I'd lean towards water damage.
这个答案有帮助吗?
得分 1
添加一条评论
overheating is probaly down to a damaged or loose ic
这个答案有帮助吗?
得分 0
1条评论:
I went ahead and did a system restore and update, has cooled down since then, keeping an eye on it. will keep the ic chip in mind i know how those can be quite the problem
完成的
添加一条评论
添加你的答案
Veronica Royal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 114
