跳转到主内容
The Toshiba Excite 10 AT300 was released in mid 2012. It boasts a NVIDIA quad-core processor, 10.1 inch Gorilla glass display, and runs on Android 4.0 operating system.
17 个问题 查看全部
its stuck on screen saver
I was given tablet it will turn on but then goes to screen saver and wont unlock,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
i want my data too what do i do?
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Try performing a factory reset using the Volume and Power buttons to restore the tablet.
Be aware that a factory reset will erase all user data and downloaded apps. It will restore the tablet to a factory default condition. It will be like it was when first bought.
Ensure that the battery is fully charged before performing the reset. Do not leave the charger connected when performing the reset procedure.
You could try the following procedure and see if it works.
1. Turn off tablet
2. Press and hold the Volume Up (+) button
3. While continuing to hold the Volume Up (+) button, press and hold the Power button
4. The tablet will start, let go of both buttons. There should be 3 Icons on the display.
(Not quite sure on this, if Volume Up (+) and Power doesn't work try Volume Down (-) and Power, if still no good try Volume Up (+) and Down (-) and Power buttons all together)
5. Use the volume button to select the middle Icon, the box with the arrow coming out of it.
6. Press the Power button to enter.
7. Use the Volume Up/Down buttons to scroll down to the wipe data/user info clean and factory default and press the power button to enter.
8. Use the Volume Up/Down buttons to scroll down to Yes (for wiping all info and restore to factory).
Once this is done, select reboot and you will be brought to the initial set up.
Be patient, it takes a little while for the reset to complete.
这个答案有帮助吗?
得分 1
添加一条评论
I tried this over and over again. my tablet goes to screen saver only, and I can't go anywhere else. I tried to reset, I tried holding volume and start buttons, i let it drain and then recharge, it i fully charged now. nothing works
can you help??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toni Schubkegel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 3,234
