跳转到主内容
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 个问题 查看全部
iPad 3 32GB doesn't load nor sync, no visible reason
I have an iPad 3 32GB Wifi, that doesn't load nor sync, also in reset or DFU mode, as if there's a power supply or cable problem. However, the supply as well as cable works with other devices.
There is no visible reason in the connector as far as I can see. I plan to pick this apart. Any suggestions what to look for?
Other actions to take first? I still have about 50% battery left
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
For the sake of doing so I would recommend blowing the charging port out with some compressed air. Beyond that it looks like the charging port is separate from the main board so it could be that it simple needs to be replaced or re seated (unplugged from the main board and plugged back in). If you have an electronics store near by you can buy a charging cable with chasing lights in it. They are kinda novelty cables however they are excellent for troubleshooting power issues. The lights only stay on if the device is taking power, the faster the lights are going the more power the device is taking.
这个答案有帮助吗?
得分 1
添加一条评论
Yeah, I'll try compressed air. Then I think I have to take it apart, though it would seem this is a little bit more risky than I thought. Also I believed I had the tools, but seems I need more, like a heat gun.
Those cables sound like a good idea.There might be something they carry in the local iPhone repair shop.
Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MiB 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 55
