跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Is ram upgradeable from 8 to 16gb?
title says it all says it all...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
No, The RAM has been soldered shut on Apple laptops for the past 3 years at least.
这个答案有帮助吗?
得分 9
1条评论:
As stated above, RAM has been soldered on to these MacBook Pro models with Retina since their inception.
完成的
添加一条评论
However, if your question was actually slightly different, on purchase you can get the 16GB option. It's a bit ambiguous as to whether you mean pre-purchase or post-purchase. Unfortunately 16GB is the limit. You can't get 32GB options.
这个答案有帮助吗?
得分 0
4条评论:
To clearify here you can buy either a 8 or 16 GB system. Once you walk out the door you can't upgrade it later!
As to supporting more than 16 GB of RAM. The processor Apple is using can support it but the high speed, low power version of the RAM they are using is only supported to 16 GB. Which is Apples reasoning on not offering more RAM.
Technically, the amount of current draw between 16 to 32 GB is so slight it should be possible once Intel signs off on the high speed, low power RAM.
The other factor here is space, the logic board layout does not offer enough space to add in the additional 4 chips without a complete redesign, this series of MacBook Pro's will not see it as a option (all three of them).
完成的
I agree, the excuse Apple is giving us about power draw does seem a bit bogus, but the largest issue is that the Ram is
1). Soldered on.
2). Proprietary, according to reports by LinusTechs. So, no luck with 3rd party, even if you were brave enough to solder your own.
完成的
@suchiththa - Be careful here, I think your mixing things up a bit. The RAM is a standards based product. What I think might be confusing is the packaging which is newer than what most people have seen in a laptop system. This memory is often seen in tablets and phones.
The SSD module is Apples own design! Here in the Function key model it's removable. But, the Track Bar models its soldered to the logic board.
完成的
@danj
Turns out I was mistaken, yes, I was confusing the state of the new SSD in the Touch Bar model with the Ram. Thanks for correcting me there!
完成的
添加一条评论
I have the same question really, as my RAM has failed in my A1708 Macbook Pro - therefore I need to buy a new logic board to replace it. - So, although I currently have the 8gb RAM logic board in my mac - is there anything stopping my from upgrading to the 16gb logic board, since I am replacing the whole thing anyway?
这个答案有帮助吗?
得分 0
2条评论:
If you are replacing the whole board, there's nothing stopping you. It's a brand new board.
完成的
Excellent answer, thank you. I was worried the rest of the macbook wouldn't support the higher RAM so this is good news. I can give my macbook an upgrade, whilst repairing. Every cloud...
完成的
添加一条评论
添加你的答案
kjyoun320 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 12,027
