跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5198 个问题 查看全部
Quick question: is touch id extension cable paired to logicboard?
I know this is probably already somewhere online, but a google didn't yield helpful answers.
Anyone know if touch id extension cable is paired to the logic board? Not the home button sensor itself, the extension cable beneath the metal shield. Has anyone successfully replaced that cable and was able to use touch id and restore fine? I know all restores should work fine even with the cable completely disconnected since apple changed it earlier this year.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
已选择的解决方案
No the cable extension is not paired to the motherboard, only the home button is.
这个答案有帮助吗?
得分 2
评论:
I can confirm this. Already replaced a few iPhone 6 and 6+ home button extension cables with and without metal plate.
完成的
Thanks, exactly what I was looking for. I'm going to do a repair like this and will update to confirm.
完成的
Just make sure you power down the phone, then disconnect the battery. If its for a customer, I heard that having them remove Touch ID purchases from the app store reduces errors but I can't confirm since I've never seen it work or not work in person.
完成的
添加一条评论
最有帮助的答案
no i dont think its paired to the logic board the actual bit that sits right next to home button is paired
这个答案有帮助吗?
得分 2
添加一条评论
No it isn't. It was in the iPhone 5s, and you couldn't really open it withourt snapping the cable. But i have opned a lot of iPhones, and lot of the 6' model. The cable isn't attached so you can open it without snapping the cable.
Happy repairing!
Greetings
这个答案有帮助吗?
得分 0
评论:
I cannot count the number of iPhone 5S's I have opened and I've never snapped a Touch ID cable on those. Saying you cannot open a 5S without damaging it is just plain wrong.
完成的
I mean is it paired in software, not physically attatched like that, and yes like josh said, I've opened many iphone 5s phones without damagind anything.
完成的
Its not paired in any way. Its just a flex cable, no ICs. Take one apart sometime. The flex runs along the LCD shield and then they put a sticker over it as some kind of insulation. You can pull the flex cable from under the insulation and inspect it. Its just traces, no IC's.
iFixit should use their fancy x-ray machine on one and put this to bed.
完成的
Yea thats what I thought. If you were to use a multimeter in continuity mode, you should be able to trace each pin to the one on the other side.
完成的
添加一条评论
添加你的答案
Ethan Chow 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 568
