跳转到主内容
修复你的物品
维修的权力
商店
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5190 个问题 查看全部
Loose-ish Home button after Front Panel Replacement
Hi,
I just replaced the front panel of an iphone 6 (space grey), and everything works fine, except for the home button being slightly loose. There is some wobble room and putting your finger on it you can feel the slight movement.
Is this a problem that can be solved by buying adhesive replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个回答
已选择的解决方案
If you are referring to the home button gasket here then yes:
iPhone 6 and 6 Plus Home Button Gasket
iPhone 6 and 6 Plus Home Button Gasket图片
产品
$5.99
这个答案有帮助吗?
得分 4
添加一条评论
This can also be down to the fact that the glass isn't right. Copy screens use thin glass and sometimes have to add bits of plastic to make the home button sit right
这个答案有帮助吗?
得分 2
添加一条评论
Trust.. The best thing to do is cut a piece of sticky tape out (the size of your home button, or maybe just a tiny bit bigger) if your pro, stencil a circle shape out and place it over your home button, it will make your home button kinda like the iPhone 7, it's a quick easy fix until a new gasket or home button is provided. you’ll thank me later ;)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mbarthet3 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 9
过去的30天: 59
总计 12,928
