Garmin Express can't find my device
I've used two computers with Garmin Express and neither one can't recognize the watch is connected. It is fully charged and it acts like no software is present.
Hi,
The user manual says that
To prevent corrosion, thoroughly dry the contacts and the surrounding area before charging or connecting to a computer.
Have you tried cleaning the contacts on the watch where the USB cord plugs into?
Does the watch indicate that it is charging when you connect it to a USB port? If it is showing fully charged, disconnect it from the PC and use the watch for a while to run the battery down a little bit then connect it via USB again and see if it starts to charge.
If it doesn't show that it is charging or even if it does and it still wont connect after you have cleaned the contacts then it is either a faulty USB cord or a faulty USB controller in the watch. If you have access to another compatible USB cord for the watch try it and see if it works. This will prove whether the problem is in the cord or the watch.
这个答案有帮助吗?
If the connection works but still can't find a satellite were can I take it to get worked on in California?
hi @dkcollier ,
As you will have all the required information the best way may be to use this link. https://my.garmin.com/rma/en-US/repair/r...
Garmin Express is an application that is used to monitor the operation of devices that monitor
your computer. It can be registering a new product, there I will provide all the things,
adequacy of information, data synchronization and other things that are remote from the
device.If you are looking for instant and genuine help to fix Garmin Express can’t find device
issues, we have mentioned some general quick fixes you can give a try whenever you are
dealing like [http:// https://gps-map-updates.com/garmin-expre...|Garmin Express won’t find my device] issues you can reach to us.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 8,783
1条评论
my S2 is charging on the computer OK but is not recognized by Garmin Express. Help.
由 martin nowell 完成的
