跳转到主内容
The Deploy CS-6 was released in 2006 and discontinued in 2010. This blaster features a clip, flashlight, action pump, and handle for easy carrying.
6 个问题 查看全部
Blaster jams and will not fire darts.
When I pull the trigger on the blaster, the darts jam inside of it and tend to bend. This simultaneously ruins the darts as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Student question
完成的
添加一条评论
2个答案
最有帮助的答案
The gun may jam due to a faulty spring after being frequently used. It can also be that you may be using the wrong type of darts. Each spring is custom made for each nerf gun based on the darts.
这个答案有帮助吗?
得分 1
1条评论:
Alec is wrong and right at the same time
完成的
添加一条评论
Maybe that the gun has chewed up bullets inside the gun.
Try to check the gun and maybe screwdrive the gun apart.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Hoff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 536
