跳转到主内容
The Samsung 5 Megapixel camcorder was released in 2011. It can be submerged in water up to a maximum of 3 meters and dropped from a maximum of 2 meters. It also records video in 1080P.
3 个问题 查看全部
Why my camcorder won't turn on?
No matter what I do I cannot get the camcorder to turn on. I have charge it for several hours and even check the led on the side is lit when plugged in. The camcorder only has a little over a year and I have used it only a few time, so I don't think is the battery. ANY SUGGESTIONS ???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Since you've tried charging it, you might have to change the screen display according to the trouble page for the device ( Samsung HMX-W200 Troubleshooting ).
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
Since you stated you tried to charge your camcorder without any luck, you may have a faulty USB charging port. But do not worry as you can follow the guide here (Samsung HMX-W200 Troubleshooting).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Antonio Abades Lescano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,320
