这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4638 个问题 查看全部
iPhone 6 home button question
I have an iPhone 6 that I am replacing the screen on. I used a different screen that has a home button to test the phone and noticed that the phone refuses to boot up with the foreign home button attached. I unplugged it and it tuned on. I plugged it in and the phone shuts off and won't come on until the home button is unplugged. The original home button works fine and the phone will come on when its plugged in. Is this a new feature in iOS 10 and will it affect 3rd part replacement home buttons? (not touch iD function I know that won't work). If its not a new feature then what would cause it to happen?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
are you plugging the home button in after the phone has been powered up?
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
It's supposed to boot with any home button. Make sure you are not plugging or unplugging ribbon / flex cables with the battery plugged in.
Otherwise if you are doing it while it's plugged in, you are probably causing shorts on the logic board which may cause it to shut off. And backlight filter can be blown when unplugging or plugging in the front display cables which results in display but no backlight.
这个答案有帮助吗?
按维修分数 2
添加一条评论
最有帮助的答案
My guess is that the "test" home button you are using has a defect in either the home button itself, or the home button long flat cable that runs under the metal plate.
You can verify by trying that same "test" home button and screen on a different known good phone.
这个答案有帮助吗?
按维修分数 2
添加一条评论
i also agree with Ben, and for whether ios 10 affect the 3rd party replacement, here is a blog which shows the experiment results whether ios 10 has an impact on 3rd party iphone replacements.http://www.etradesupply.com/blog/ios-10-...
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
CAB 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 85
