跳转到主内容
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
70 个问题 查看全部
My HTC ONE M9 digitizer cracked mysteriously.
Hello, today my M9 was going crazy while scrolling throgh Instagram and after I restarted my device it was doing the same thing, so I installed a touch screen tester and I saw that I was having a little crack right by the volume down button in the digitizer. I've dropped my phone a couple of month ago, but it was with a case and a tempered glass screen protector on it. I want to say that the glass isn't cracked, and I've also lost my warranty. Is the display assembly fused toghether?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Yeah it pretty much is. Fused really well. You will have to replace the screen to fix that problem. I recommend buying with screen with frame as it's really hard to remove the LCD without making cosmetic damage on the frame.
Source: Replaced a few HTC One M9 screens.
I really have no idea how the digitizer layer would crack inside the screen. Because the frame and LCD are very sturdy for original, OEM, never repaired HTC One M9.
You can use this guide to disassemble the phone to the screen, though I only recommend doing for the black / darker colors because on the gold one the finish on the gold color can be scraped off to black when removing the LCD:
HTC One M9 Display Assembly Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mihai Zaim 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 525
