跳转到主内容
Laptop hibernates when lid closed and game playing?
Asus Laptop N56J running Windows 8.1. I want to run an external monitor as my only source of a screen for my laptop while it's at my desk.
Any time the lid of the laptop is closed AND a game is running (have tested steam games and independent from steam, like GW2), between 2-5 minutes the laptop hibernates. If the lid is up, there is no issue.
ALL power options are set to avoid sleep and hibernation with and without the power cord. The screen is suppose to turn off but not sleep or hibernate.
I have set all screen resolution settings to the optimal settings for the three separate monitors I have tried. It happens as long as the lid is closed. The main screen is the external monitor and laptop screen is disabled.
The laptop does NOT get hot. It doesn't seem to be an overheating issue.
It's NOT shutting down or sleeping. I need to use the power button to turn it back on but when I do, all programs, including my game, are right where I left them.
Even though I don't think it's anything to do with the monitors itself, I have tried connecting external monitor via HDMI, VGA, and a DVI to HDMI cable.
Latest drivers for laptop were installed to try and fix the issue. It did not.
The only thing that has changed this issue at all is messing with the ATK hotkey packages:
-Deleting ATK Hotkey package. This solved the hibernation issue BUT instead of it hibernating after the lid was closed and the game is playing, the entire laptop restarts instead.
-Installing the most up-to-date ATK hotpackage. Back to hibernation issue.
-Tried Asus power manager. No help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi,
Not certain if this works for Win 8.1. (I'm using Win 10)
Press the Win key + p key together. When the Project box appears select the second screen only option to turn off the laptop screen.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
hello,
If you don't want hibernation and free up some disk space you can disable it in Command Prompt,
Go to command prompt by searching it or (right clicking) the Start windows logo and click Command Prompt, Once you do and the DOS command box opens type:
powercfg.exe -h -off
then press enter
hibernation will be disabled and youll notice a few extra gigs of space for games :)
这个答案有帮助吗?
得分 5
2条评论:
Just to Note: if you want it back type powercfg.exe -h -on
完成的
Prior solution does not work in win10 & 11 for two reasons.
One need to ensure you do this command from an elevated command prompt
Two syntax error you put a - before the on / off switch incorrect.
Below is the correct way.
Press Ctrl + Shift + Esc to open Task Manager in Windows 10. Click More details to open advanced mode of Task Manger if you need.
Click File tab and choose Run new task.
Type cmd in Create new task window, and make sure the Create this task with administrative privileges box is checked. Click OK.
Click Yes in pop-up User Account Control window to open the elevated Command Prompt.
powercfg.exe -h off
完成的
添加一条评论
添加你的答案
Rya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,080
