Why wont my tablet turn on?
My Insignia Flex 10.1 NS-P16AT10 wont turn on even when it is plugged into the charger. Can you please help?
Many of these new tablet chargers have AI (Artificial Intelligent) which tells the tablet how many times to charger the battery and information has to be identical from the tablet and logic board on the battery. Most of the times improper battery charge can confuse the information and the tablet becomes stuck or halted.
Step 1.You need to plug your unit into the wall then wait for it to show the battery symbol. Some times it takes 30 minute to an hour to show (depending how low the battery is).
Step 2.If that does not work your next step is to clean the plug from the power adapter connection and the tablet connection with alcohol. Get a cotton swab and dip it in alcohol and rub it gently on each connection. Make sure the alcohol in the connection of both tablet and adapter to where it looks covered in it. You can then air can spray it or let it dry on its own (better to use air spray). Once that is done – do what I mention in the beginning of this instruction (step)1.
Step 3.If that does not work you will need to open the tablet with the tool you can purchase on Fix It or on ebay and remove or unsold er the red and black wire of the battery and leave it off for 5 minutes. Then connect it by soldering it back and do the same as mention in the beginning on step 1.
Step 4. If that does not work you will need to test if possible your power adapter on another tablet that has the same voltage and amps. It may be a bad power supply. If it is bad power well it is time to replace it with a new one. Remember when pluging your power supply to the tablet - that you place it on a flat tablet and make sure that the wire is not bent down and it is at lease 4 inches away from the tablet. Wires on many of these power supplies can be broken just like when you take a peace of metal and bend it up and down it will snap.
These are the best way to get your tablet back up again.
这个答案有帮助吗?
Its probably your charging port.i suggest u dismember the tablet and get a new charging port. STAT! That iz my answer.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,027
Student question
由 mayer 完成的
