跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
Horizontal line after PRAM reset
Hi all,
Today I did the reset on the PRAM. The laptop started fine, but when it loaded almost completely, the screen showed a horizontal line. After that the screen was black and turnt on again. After that the laptop started fine. I saw about a recall of the 2011 models, so I think I'm going to send mine to Apple.
But has someone else had this problem? I read that It could be something with the FileVault, which I had on. I turnt it off, but still got the problem although the files are being decrypted atm.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I have seen that line several times on different machines but only in the last month. Are you running Sierra? Let's also see if @danj has seen this.
这个答案有帮助吗?
得分 1
7条评论:
@mayer Yes I'm running Sierra. I read that is could be a 'glitch' with this OS and model machine. But strange that this is happening after the PRAM reset, or isn't it?
完成的
See if it is hitting about 60% of the way through the loading bar progress. That's when it loads the video driver.
A kind of similar glitch was happening in safe and recovery mode with the display flopping during loading in El Captain.
完成的
@mayer but the stripes appear as the photo shows, so about 45%.
完成的
Mine may hit a little later because of all my added programs. I really don't see an issue with it right now. Let see if others have noticed it.
完成的
@mayer but don't you think it's strange that this happened after the PRAM reset?
完成的
显示更多的2条评论
添加一条评论
I would definitely go to Apple and have them run their internal test software to see if this is affected by the recall.
Do it soon, I'm sure you will, because the date at which this extended service program ends is the end of this year, 2016. After that, they won't replace it for free.
这个答案有帮助吗?
得分 0
3条评论:
@skippingrock can you give a link as to when this program is officially ending because I have not seen it.
完成的
@mayer https://www.apple.com/support/macbookpro... at the bottom it says: The program covers affected MacBook Pro models until December 31, 2016 or four years from its original date of sale, whichever provides longer coverage for you.
完成的
Uas Thanks for reading the fine print
完成的
添加一条评论
添加你的答案
Uas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 320
