Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
这个答案有帮助吗?
You need a new Turn Signal Switch, relatively cheap part
这个答案有帮助吗?
Bulb replacement solved the problem
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 121
1条评论
Bulb replacement worked. Thank you
由 Dennis Johnson 完成的
