跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Why are there 2 white spots on my screen
My iPad has two white dots on the top left corner of it and I don't know how to get rid of it, my iPad has been glitching lately too well I call it ghosting because it moves and types without me even touching the screen. I think the dots are there because of the glitch but I'm not quite sure does anyone have any idea what they are?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
8条评论
My new iPad Air has this too.
完成的
Same with my ipad Air. 2 dots & freaking out. Opening apps, emails everything without anyone touching it.
完成的
Do you know how to fix it
完成的
How to fix white dots on my iPhone screen
完成的
Answer: Reboot your iPhone.
完成的
显示更多的3条评论
添加一条评论
7个答案
已选择的解决方案
If you could post pics of the dots, that would help.
From what you have described, it sounds like a bad digitizer. Easy and cheap to fix. The white dots could be marks on the LCD, but without pics its not possible to say. I would start with changing the digitzer and would inspect the LCD while I was in there. Chances are that the spots are on the digi and the LCD is fine but the LCD could have also been damaged and need replacing.
这个答案有帮助吗?
得分 3
7条评论:
I posted the question and solved it myself. With my new ios 12.0.1 it seems to be an indicator that the wifi is off. But I can touch it and get into the control center. How neat and handy. Nothing malfunctioning — just a new way to cc .
完成的
I had these same spots, same place today. I rebooted my iPad and they disappeared.
完成的
Hi i have the same problem too but i have only 1 white spot on my upper right corner near the battery bar, i tried rebooting my ipad but its still there...
完成的
I have the same problem and I want to know what it means.
完成的
You need to turn your iPad or iPhone off and the 2 dots will disappear.
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
No, it's a software glitch. Just restart your phone and the two white dots will go away. It happened to my iPhone when I was wiping clean my screen.
这个答案有帮助吗?
得分 8
6条评论:
The exact same dots just appeared on my iphone for the exact same reason and restarting the phone worked. Thanks :)
完成的
Thankyou very much. I've been very nervous about this.
完成的
Exact white spot on my iPad; restarted white dot disappeared.
完成的
Thank you. It was driving me nuts!!!
完成的
May i ask. Why were there two dots in the top middle of my screen?
完成的
显示更多的1条评论
添加一条评论
Yes Genius your right it's just a glitch. It randomly happened on my iPad Mini 4. I just shut down my iPad turned it back on and the dots disappeared .
这个答案有帮助吗?
得分 3
3条评论:
dats true its slolved in my case thank you
完成的
I had one white dot in the top left of my screen that appeared today for first time after owning phone two years.
I happened to swipe my screen all the way to the left where weather, calendar, etc alerts appear. Bottom of all those alerts was an alert “you have one widget to review”. I reviewed that and the dot magically went away. Not sure if there is a link between the two just yet or not. But reviewing the alert made the dot disappear seems like.
Anyone else havethis happen?
完成的
This is actually what you should do, followers these intructions and saw the “3 widgets for review” at the bottom of my screen, clicked on it, and the three dots went away. such a weird way to alert people apple but this seems to be the fix without having to hard reset your iPhone.
完成的
添加一条评论
Could be liquid damage (can cause a light patch where the liquid leaks onto the LCD) or the white mark could be caused by impact damage to the LCD, difficult to tell without seeing it. Are you able to add a picture?
In terms of the touch issue, has the iPad glass screen been replaced before? May not have been insulated properly by the company who did the repair. If not, it is again likely caused by liquid damage.
这个答案有帮助吗?
得分 2
3条评论:
I have a white dot on my iPhone 7. It happened after I had an “iffy” text from a friend on instant messenger. He kept telling me to text a number but the wording did not sound like him. The dot is on every screen. The word screen on my phone the s is blocked out by this one dot. I’ve turned my phone off several times. Any ideas
完成的
Hope this helps...
完成的
New iPad, generation 4, magic keyboard. I tried rebooting and that didn’t work so I read all the comments and then it started to make sense. Disconnected the Magic keyboard and the dot disappeared. Magnetic hold a bit strong, won’t be using it any more.
完成的
添加一条评论
The white spot is dead pixel, to fix it please visit this article Tips on How to Fix Dead Pixels on Your Screen
这个答案有帮助吗?
得分 1
1条评论:
Same exact issue on my i7+ screen... there are 2 white circles/dots, 1/4 inch apart, that appear near the upper left corner of the screen (btw they're not water spots)... they're 2 very distinct white dots/circles about 1/2 the size of those tiny "collar" buttons you typically see on a man's long sleeve business shirt. Incidentally, my i7+ has an aftermarket screen and has been ghosting a lot recently (aka: typing random gibberish, randomly opening apps & randomly calling ppl from my contact list).... If I didn't know better, I'd swear my cell was possessed or someone was hacking into it - lol - Anyway, hoping this info will help someone else out and/or help figure out the exact cause of the problem.
完成的
添加一条评论
I agree that this seems to be a glitch. I just had it on my iPhone7 (iOS 12.1.4) after my twin toddlers had my phone for a few seconds LOL
Reboot and they are gone.
I really wanted to know what their function was, or what my twins did to cause them to appear.
这个答案有帮助吗?
得分 0
1条评论:
My 1 year old managed to do it to my phone too. She had it then I got it back and there were two dots in the top corner. I was sure she messed something up lol.
完成的
添加一条评论
I have two dots above my iMessage and have a pic to show it but cannot figure out what it means can someone tell me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yuli bronshtein 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 20
总计 183,068
