跳转到主内容
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, and a new set of trigger buttons.
65 个问题 查看全部
Is there any way to fix water damage on the device?
Device got wet and now the device doesn't power on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个回答
最有帮助的答案
@gouda just like any other water exposed device you want to follow some simple rules. To start with stop trying to turn it on or to charge it. Remove the battery. then disassemble your device completely. Clean every part with a high grade (90%+) isopropyl alcohol. Do not forget to remove the EMI shields on the motherboard. Clean all the connectors as well. Yes, it is okay to submerge the board in alcohol. When they are properly cleaned, let them airdry for a brief time. Then replace the battery with a new one. These batteries will fail so you will have to replace them for proper trouble shooting. Once you have done all that, reassemble your device and now you can charge it or try to turn it on. Let us know what you get,
这个答案有帮助吗?
得分 2
评论:
Darn just recognized this as a student question. Sorry, did not mean to interfere with your assignment.
完成的
No worries @oldturkey03 ! Your answer is accurate and greatly appreciated.
完成的
添加一条评论
The best way to handle this problem is to take apart the device and clean it. Remove the logic board. If you are unsure of how to do this, reference the logic board replacement guide (coming soon). Use 91% Isopropyl Alcohol and a soft brush to clean any corrosion inside the logic board. Allow the logic board to dry in sunlight. Reassemble the device and check to see if it works. If it does not work, you may have to replace the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ahmed Gouda 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 255
