Why can't I access my keyboard while trying to text a message
Why can't I access my keyboard while trying to send a text message? The keyboard will not open
Hi..I just went to my apps and checked the gboard app which is the keyboard i use and it needed an update and walla ..i go back to messenger and my keyboard is again working. Hope this helps! so much for automatically downloads the updates eh?
这个答案有帮助吗?
Thank you! This also worked for me
you rock!!!! thank you so much!!!!!
go to settings > application manager > find your keyboard app to the download section if its is downloaded thru play store but if your keyboard is system app check it to running section and press your keyboard app then you will be directed to keyboard setting and the press the clear data button on your screen then reboot your phone if necessary..
thanks.
这个答案有帮助吗?
all section my mistake ^_^
When I use voice text when I am messaging a person on a date site, my phone all of a sudden delete it, does anyone know what’s going on
Had same problem. Go to Settings. Then Apps & notifications. Tap App info which will take you to your list. Scroll down to Gboard. . Enable! Works
这个答案有帮助吗?
This one was most helpful and to the point. I had to put gboard in search because when I scrolled down if wasnt there, but it worked!
Thank you, so much!!!
Kudos & appreciation!
过去 24 小时: 29
过去 7 天: 203
过去 30 天: 1,019
总计 41,795
20条评论
cannot type on my Messenger on my phone why
由 Kalima ALI 完成的
Keyboard does not appear on my phone to send text messages
由 lee.berteit37 完成的
I am not able to type
由 Rosa Gray 完成的
I had this problem too and it kept putting hyphened or other language letters too. Re installed Google keyboard and deleted all languages except English and seems to be working like it's supposed to!!
由 Lisa Muir 完成的
@Kalima ALI
Try deleting all languages except your own and re install Google Keyboard. I just figured this out myself and it's working as it should!!
由 Lisa Muir 完成的
显示更多的15条评论
