跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
What is the + sticker on replacement iPhone 5s screen full assembly
The replacement screen and digitizer full assemble from IFIXIT has a round '+' sticker in the lower left hand side, next to the home button hole. What is the sticker for? Should it be removed before reassemble?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Where is this sticker? You need to provide an image of what you are talking about
完成的
A picture would help but unless it is in the way of assembly it would be best left alone, assuming it is on the back side of the screen. If it is on the front (the side you will be looking at while using the phone) then it should be safe to remove it.
完成的
Sorry. Trying to post a picture.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi!
It should be safe to remove the sticker. I think it just shows you what type of screwdriver to use.
这个答案有帮助吗?
得分 1
添加一条评论
You can let it there. It is a sign of the seller of this diplay unit, in this case it is the logo of iFixIt ;)
Other seller use other stickers or signs to identify their stuff in case of claims.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the help.
完成的
添加一条评论
添加你的答案
Charles Farnsworth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 134
