跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
I've swapped the brake switch but now I'm clueless.
Hi
I'm having trouble with my Vauxhall zafia. My tail /brake lights work as they should when ignition is off but when on or turn the key then they are on at all times. I've swapped the brake switch but now I'm clueless. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Adam, to answer your question we need more info. year, make, model,engine, transmission and , which switch did you change, after changing switch what is it doing, Any damage,accidents,recent work,etc.
The more info. the better ifixit can answer your question more effectively. Thanks.
完成的
Hi, Try removing the brake light fuse (is it OK?) and see if it comes on either way i.e. with ignition on / off. With the fuse removed and the ignition on, if they still light then you will have to trace where the power is coming from.
Here is a link to the wiring diagrams for 2001-2004 Opel Zafira. Hopefully yours will be similar and this is of some help.
ftp://toksvaerd.dyndns.dk/Uploads/Bil/Op...
完成的
添加一条评论
1个答案
已选择的解决方案
Adam, Recheck brake switch to see that it is adjusted correctly, on some vehicles the brake pedal may drop slightly due to computer cycling anti lock,brake motor,etc.( with an assistant, with key on, pull up on brake pedal to see if brake light goes out). If light does not go out check all wires/sockets to rear tail/brake lights for corrosion,damage,burnt/melted, bare wire causing a short. Also if you have a trailer light hook up, especially if it has a inline trailer light converter unhook it, as they can cause issues when they become faulty or short.
Good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 115
