跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 backlight. Apple logo then no display
After a screen replacement the iPhone goes to the Apple logo for about 3 seconds then lcd dims completely. Have tried multiple screens. Phone still reads in iTunes. I don't want to try restoring just yet because of customer data.
I already replaced the filter and still showing same behavior. Tested the three caps for shorts and all are good. No signs of shorts anywhere in circuit that I tested.
Coil itself visibly looks good with no signs of damage. Also main lcd connector shows no signs of damage.
Does anyone have experience whether this is possibly the diode or driver ic? Since it's near the cpu I want to avoid as much heat as possible.
Any suggestions would be great, thanks again!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
the error cannot be grounded caps as you see 3Sec of live LCD, check with original LCD which is phone had.
完成的
Thanks for the reply. I already tried original (2 in fact) lcds and same behavior. I'm wondering if boost ic is giving enough voltage. Gonna play with that this weekend.
完成的
Does itunes say its in DFU mode?
完成的
I 2nd Allan Hill's comment, I've been seeing this more and more lately, where the phone won't show the dfu symbol just a black screen. took me ages to work it out the first time. good luck
完成的
添加一条评论
1个答案
最有帮助的答案
In addition to @brokegadget suggestion, you may try to turn your phone to DFU mode. I would suggest you to check & clean (using the right process) the connector pins.
Hope this helps,
Vincent
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stephen Elliott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 409
