跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Replaced Battery phone restarts every 10 minutes
I replaced the battery in my iPhone 3GS and now the phone restarts every 10 minutes and wont charge due to restarts. What could the problem possibly be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
6条评论
Have you tried a restore in iTunes?
完成的
I tried a restore and gave me an error message saying restore could not be completed
完成的
What was the exact error message?
完成的
The error message was #29 and I did replace the old battery with a new one and thats when it started. Im going to put the oem battery back in and see if that goes away.
完成的
Yes, error 29 means a bad battery -- you might need to return your new battery to wherever you bought it for a better one. See e.g. Try to restore get a error 29
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
I'd check some of the other questions regarding this issue. There was mention that an oem battery causes iTunes fault ?28&1601.( apple can't recognise the hardware) I'd also replace the old battery and see what happens.
这个答案有帮助吗?
得分 2
添加一条评论
Try to put orignal bettey it should be ok
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,416
