跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
4127 个问题 查看全部
What is the best air purifier for soldering logic boards
we're going to be expanding our skillsets so we can start soldering logic boards, and we know that we need some form of air purification system.
we'd like to have small air purifiers right by the station, but also we'd like to have a larger air purifier for the entire work space of multiple stations.
Can anyone tell me where to look for information about the best types of air purification systems?
also, we're looking at doing some reflowing as well, so we know that there will be fumes released that need to be cleaned up
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
dollar, If you are going to have employee's, you are liable for their health and safety, Best to talk to an HVAC engineer/specialist to see exactly what is required by law for your business. The rules can be pretty stringent to prevent illness,etc.
这个答案有帮助吗?
按维修分数 2
评论:
dollartripclub, thanks for acceptance, this really is the best way to go if employees are involved and for yourself protection. Good luck with your venture.
添加一条评论
最有帮助的答案
You really can't purify the air, but you can exhaust the dirty air outside!
I would get a stove range hood setup with it vented outside for your work bench which has the rework station as well as the hotplate.
I use a small fan to pull the fumes away from me when I do the small stuff. Mine is so old the company has long since disappeared. Here's one that is on the cheaper side:
Some of the guys have this one:
Which I think is more useful but more expensive.
The charcoal filter these have collect the resin's in the fumes, metal vapors don't really collect in the filter as you need an ionic plate to catch them.
这个答案有帮助吗?
按维修分数 2
添加一条评论
I use a dental lab bench with a built in fish mouth vacuum system.
http://handlermfg.com/products/index.php...
These can be built into a duct type system. Mine has a sliding door behind it to open or close it. The actual vacuum can be in another room. Then when you slide the door open it activates the system and you get suction only in the location where it is open.
Looks like this: https://www.harrisdiscount.com/products/...
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
dollartripclub 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 94
