跳转到主内容
The Samsung NX Mini is a mirrorless digital camera released in March 2014.
8 个问题 查看全部
Zoom lens won't unlock
I have never drop this camera or taken off the lens after first putting it on. It's been about 9 months since I had this camera. The zoom lens won't unlock after rotating it like I normally would. This has been going on for 2 months. What can I do to fix it so the lens will unlock and I can use the camera again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
I had this problem too. I took out the 3 outer screws on the back of the lens, one seemed loose, peeked in and decided there was no way I was going to fix this thing. Screwed it back on and the camera worked again. I suspect the screws were loose. Give that a try and see if it works.
I know I was about to throw my NX-mini out when I took the chance of unscrewing it. I wouldn't try to remove the back. Just try tightening the outer screws.
Update (10/27/2017)
Update: It stopped working again.
I had a technician at work take a look at it and he found that a ribbon cable in the lens sheared. He removed the cable and it works, kind of, in manual mode. I will be sending the lens to International Camera in Chicago to have it repaired.
这个答案有帮助吗?
得分 3
4条评论:
Thanks Man. You really helped me.
完成的
omg thank you so much this helped
完成的
Its a really answer, thanks a lot brother
完成的
Thank you! Great!
完成的
添加一条评论
It works for me too. Just tighten the 3 outer screws, then on off once.
这个答案有帮助吗?
得分 0
添加一条评论
You legend! Thank you!!! It worked. Might I add that I had to remove the three outer screws and put them back in before I was able to successfully fix it. So thank you for sharing your answer.
这个答案有帮助吗?
得分 0
添加一条评论
Well you should go to near camera repair or hardware repair shop and give to some one who have the proper knowledge of how to fix this type camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
katiexyooj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 4,850
