跳转到主内容
This is the non-touchscreen version.
9 个问题 查看全部
How to I factory reset my managed chromebook
Hello, I purchased a chrome book off of craigslist. I found that it was a managed device ive tried several ways of rebooting , power wash, esc, refresh, power even reinstalling the operating system, but didn't get any accurate results. Is there a way I can go inside the chromebook and reset it from there? It's kinda useless as a home laptop if I can't do anything on it. The model is a Dell chromebook 11
Any tricks to return it to factory ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
Have you tried asking the Craigslist seller?
完成的
Yeah, unfortunately he hasn't responded to anything i've sent and I reported him to the community. If i can't get a hard reset to work on the computer then i'll just buy a new one from Best Buy
完成的
sign in press ctrl+alt+t it will open crosh then type rollback and see if that helps
完成的
添加一条评论
2个答案
已选择的解决方案
Depending on the newness of the model removing the program screw will not remove the management. It’s up the to the business or place thats managing the device to release the management. You can perform a simple powerwash which is ESC+REFRESH+POWER then CTRL+D then space bar and enter. This will wash the device but depending on the managment you may need credentials from the original manager to enroll the device.
这个答案有帮助吗?
得分 4
添加一条评论
you turn off your chromebook and press ctrl+esc+refresh+power button than ctrl+d than enter than ctrl+d
then you have to take out the write protect screw near the HDMI port you have to open the chrome book though
it will reboot factory reset.
这个答案有帮助吗?
得分 1
1条评论:
I purchased a chrome book 3100 and unfortunately it’s managed I suppose, I took the back off to replace the hard drive and I can’t find it.. Am I just over looking it? Does it not have a hard drive because it’s managed?
完成的
添加一条评论
添加你的答案
Elliot smith 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 71
过去 30 天: 318
总计 11,958
