跳转到主内容
Released in 2010, the HP Deskjet 1055 is an all-in-one printer, scanner, and copier.
I changed the ink but it won't print
I changed my ink both black and tri color but my HP Deskjet1055 Printer won't print
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
do you get an indication light ....error sign
完成的
Yes on my ipad
完成的
添加一条评论
3个答案
Hi Sharon, if your HP printer is still unable to print after recycling the Ink Cartridges, it's most possible due to improper alignment of it.
Try these steps:
Open HP print manager -->> Select setting and maintenance -->> Select align print cartridges
Now take out printed paper, you will see two dot lines parallel in red and black. Examine the alignment of the lines, click the numbers and letters for the best alignment, a dialogue box will appear to your screen, click continue, a new page will be print, now check whether these alignments are correctly printed on the paper, if you found irregularity over alignments, repeat this step 3 or 4 times to continue.
h/t: How to Set-up Print Cartridges to the HP Printers?
这个答案有帮助吗?
得分 0
添加一条评论
i changed the ink and now the printer isn't working right
这个答案有帮助吗?
得分 0
添加一条评论
إمبارح عملت نعم بل فعل
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharon Laughlin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 8,563
