跳转到主内容
The Stream 7 is a compact multi-use tablet produced by Hewlett-Packard and was released in September of 2014.
11 个问题 查看全部
Why won't my Hp Stream 7 turn on?
I can't turn my tablet on and it's starting to frustrate me >:( any ideas on how to fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hey Brennan!
Sorry to hear about your struggle, but I think I have some ideas that could help!
- Try charging your device. It's most likely dead and a little charge could do the trick
- Try changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
- Water damage is a possibility. If you have soaked your device recently, you may have some luck dissembling it, and soaking the parts in rice or salt; neither will guarantee your device will work when put back together, but success stories have brought devices back from the dead.
Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
Hey Brennan!
- Try Changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brennan Slater 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 545
